Hi guys currently trying to get my sato clips fitted in place of the pillion pegs, aaaaaaaaaaaaaaahhhhhhhhhhhhhhh!!!!!!!! Anyway been on here followed the link though only thing I cant work out is how to remove the under tray to get into the lower bracket. Can anyone help. Merry Crimbo http://1000rr.co.uk/images/smilies/mad.gif
by undertray do you mean the coloured plate (part of the fairing)...? Glossy and nice - not grey plastic. if it is the faring plastic which sits above the shock, then i ended up drilling a hole the battery tray in order to get to the phillips head screws. I drilled the lump in the top corner of the batt tray and it comes out directly above the screw - but there are other methods. Also are you ABS or non ABS?.... I have Sato street hooks - awesomeness.
Hi guys found an excellent vid on you tube that shows u exactly how, guessing all may have seen it anyway here it is Hotbodies Racing CBR 1000RR Undertail Installation Guide (Part 1) - YouTube, the info i got from the other members within the forum best just splitting the rear subframe and remove the rear pillion pegs one by one . Anyways happy as job done
Sorted and got them on, what a difference looks wise. A followed link bellow on you tube bro which worked out ok. Well happy the result. Just need to figure out how to put my diamond rear sets together now and ill be sorted
