Remove passenger foot pegs
Discussion in 'General 1000RR Discussion' started by Willie 1000rr, May 21, 2017.
  1. Willie 1000rr
    Willie 1000rr Active Member
    Hi all, anybody a link or thread on how to remove rear passenger foot pegs, losing patience! Lol. 2016 blade. Cheers
  2. sps170373
    You'll find better how to's on YouTube
  3. blake7
    blake7 Active Member
    Remove rear cowl, split rear subframe removing one side at a time. One side off, unscrew peg, refit and then do the same on the other side. This keeps the battery tray in place.
  4. Blade runner 1
    Blade runner 1 Elite Member
  5. lexathon
    lexathon Active Member
    These are my notes from my iPhone... for an abs model, if it's not abs then ignore the abs bits!
    Credit to wherever I copied the base from, but can't remember where (or if I even copied them in the first place!!)
    CBR1000RR Pillion pegs removal / reinstall
    Remove pillion seat
    Remove seat
    Remove tank cover bolts (or entire tank cover)
    Remove 4 cowl fairing bolts
    Slide cowl back (when re-installing, ensure tabs are slid into place at bottom)
    Remove 4 bolts holding pillion seat catch mechanism
    Pull fuse box out (use a screwdriver to release clip)
    Remove bolt under fuse box
    Remove 4 bolts under cowl
    Remove small plastic popper screw on rhs under cowl
    Cowl will now drop down
    Remove bolt holding side arms together
    Remove 1 side at a time:-
    2 big bolts (54Nm) - bottom bolt has a nut behind it - be sure to catch it!
    1 bolt holding tank in place
    2 bolts under cowl similar to catch mechanism
    On RHS remove two bolts for abs pipe stay (be careful when reinstalling and make sure cable and pipes not caught)
    RHS has abs stay clamp and bolts are in place with spacer nuts - disregard spacer nuts when reinstalling pegs.
  6. Willie 1000rr
    Cheers men all sorted!!
  7. Jimmy46
    Jimmy46 New Member
    Brilliant thanks wonder why Mr Honda made it so difficult
  8. nigelrb
    All of us with 08 - 16s ask the same question. 04 - 07s are easy as are 2017 - 19s. I think it was just the 'neatness' factor.
