removing 06 gearbox
Discussion in 'Maintenance' started by racman, Feb 26, 2016.
  1. racman
    racman Active Member
    is there a how to remove the gearbox on here. if there isnt, can anyone give me the basics. for example, remove clutch, remove gearbox. but with the main things to look out for.
  2. scooby
    scooby Elite Member
    it's quite easy as it's a cassette box.
    basically.
    drop oil-to make life easier
    remove clutch cover
    remove clutch,starter gears,clutch basket,this can be a little fiddly as you need to line up with a flat spot on the crank.
    then remove the gear box,from memory it's just 4 bolts.be carefull not to let it fall apart as can be fiddly putting back together
  3. Dave
    Dave Member
    As scooby says, there is something to watch for on re-assembly but can't remember:confused:, think its a locating dowel or something similar, i remember having to have a couple of goes at re locating the gears on one a few years ago:mad:.
  4. scooby
    scooby Elite Member
    it's the starter gears that can be tricky to get back in place as the little shaft locates into the engine side case but wobbles around a bit.
  5. Dave
    Dave Member
  6. derchef
    derchef Well-Known Member
    may a workshop manual?
  7. racman
    box is out . piece of piss. just deciding what to do with it now
  8. scooby
    scooby Elite Member
    ahh just realised you have the 06/7 box,with regard to my spare box,it's for an 08- so don't think it will be any use,unless the gears are the same on both boxes.
  9. racman
    k mate. cheers anyway
  10. derchef
    35 minutes work ;)
  11. racman
    yup. i did that and then a clutch on a hyundai tucsan. a very productive saturday
  12. dansp1
    dansp1 Active Member
    Loads on US eBay, search transmission rather than gearbox
  13. racman
    thanx dan. your right , there are a shedfull and cheap as. do you know how much shipping would be, as i have never bought from usa before
  14. dansp1
  15. dansp1
    The dearer one looks better to me, make them a ceeky offer, if the price comes down the import duty shown should come down too
  16. racman
  17. dansp1
    prior
  18. racman
    ha ha, never noticed that before dude. you must be the only one that has spotted that.
  19. racman
    bought this one dude. was £139 inc shipping. if its a good box, which they have assured me, i think mega bargain compared to the 2 on ebay uk, both at 4 to 500 pounds each
