Removing baffle from road legal (e-marked) Akrapovic
Discussion in 'Mods, Upgrades, Accessories and Products' started by ccr32, May 11, 2015.
  1. ccr32
    ccr32 Active Member
    Yeah.... you can't. The bolt is welded in.
    Only took me two and a half hours, cut hands, lots of swearing and shouting and nearly a damaged carbon end cap to find out!
  2. sps170373
    I had a road legal akrapovic and no problem taking the baffle out, just pull out rubber bung and undo Allen bolt
  3. ccr32
    ccr32 Active Member
    Defo not on mine unfortunately... It's a 8mm bolt (rather than allen bolt) on mine which for starters meant that the hole in the carbon end cap had to be enlarged just to fit a socket in there, and then on closer inspection you can see that the bolt has been spot welded to the metal of the can in two places. Suffice to say, it didn't budge when I did get a socket on to it.
    Would have taken a photo only I was too pissed off by that point!
  4. Cbrjay
    Cbrjay Well-Known Member
    Mine came out ok, but heard of one other that had the problem.
  5. Greco
    Greco Active Member
    Ccr32 still laughing mate with your reply!! Haha
  6. charger
    charger Active Member
    Dremel the hole just a little and a thin walled socket fits. The weld breaks no broblem when you turn the bolt open.
  7. graemewalker
    graemewalker Elite Member
    Mine came out no bother as you described and it was e marked road legal,just managed to get a socket in 8mm I think to mind the weld was on the nut end ,
  8. ccr32
    ccr32 Active Member
    I did get a socket on there in the end (8mm), though it seemed to slip straight off the bolt end as if the edges had been rounded. I gave up shortly thereafter not wanting to completely balls up the carbon end cap.
    Though Charger, why'd you have to go and post something like that (that the weld breaks easily) - I want to give it a go again now!!
  9. charger
    so, you do it again, remove the baffle this time and enjoy your exhaust as it's meant to sound :).
  10. ccr32
    ccr32 Active Member
    Useless home mechanic 1 - 0 Titanium baffle bolt
    Managed to get the fecker out today at the third time of trying, this time using a little more than just gentle persuasion, i.e. an impact driver. Didn't think it has worked at first but persistence pays off it seems!
    So glad I did manage it too - the 'blade has got her voice back again! Sounds very deep and throaty now, with some nice little burbles on the overrun, and crucially (for me) a solid idle (at last!).
