What's the best way to disconnect the mirrors can't see the plugs unless I have to take the front fairing off which I don't want to do??
you can pull them out, the connections are in a rubber sleeve but if your careful it will come out of the space and use a small screwdriver to undo the connection.
yeah take out all the retaining allen key screws that hold in the screen and the front fairing should be more bendable lol then unbolt the mirror and pull the wires and you should see the connections in their sleeve just get a very small screw driver or pic to pop the connections off easy
