Removing overflow catch tank.
Discussion in 'General 1000RR Discussion' started by Lifeofriley, Jan 19, 2019.
  1. Lifeofriley
    Lifeofriley New Member
    Rather than removing the swingarm is there a easier way of doing this? Maybe removing the shock? After some tips before I throw some f#**s. Cheers
  2. Bikerznod
    Bikerznod New Member
    Did it last weekend..... you can do it by just removing the shock and the shock brackets and lowering the swingarm.
    • Downvote Downvote x 1
  3. Lifeofriley
    Ok dude will give that a bash later. Thanks for your help
  4. Lifeofriley
    Completed it. As above a easy job to remove once spring and shock brackets are undone. Had to raise the rear with a pull lift as I struggled to get a jack to lift the bike safely. Please with the job.
  5. Bikerznod
    Nice work, looks similar to what I've done.. only I've taken the fuel overflow on the other side nd put a breather tube in the radiator bottle. 20190129_121612.jpg
  6. Lifeofriley
    Ah I see what you done looks nice. My tank over flow and breather are joint together under the tank 2.1 spitter then just go into the one bottle.
