Removing Tank Cover on 2011 Fireblade.
Discussion in 'General 1000RR Discussion' started by shere, Jan 26, 2015.
  1. shere
    shere New Member
    Hi, how difficult is it to remove the tank cover on a Fireblade 2011?
    Mine needs a respray so need it off so that the sprayers can do this for me.
    Please let let know how to do this.
    Thanks
  2. Slick
    Slick Elite Member
    easy peasy,
    remove seat , then remove two allen bolts holding the rear portion, then the two allen bolts at the front, either side of the HESD. Get fingers under the cover left and right then gently pull off!
  3. SIDEWAYS
    SIDEWAYS Senior Member
    Unclip the seat panels.Unscrew two philips screws securing seat on.5mm allen key to undo 4 allen screws 2 underseat and 2 at the sides near forks.
    You literally pull it upwards off the tank filler seal.To replace I wet the tank filler seal so that the cover slides on easier.
  4. Slick
    Slick Elite Member
    just as an added note, there are two 'special' washers on the front, be careful not to let them fall into the fairing/engine compartment, easy to fall out nearly impossible to retrieve!
  5. shere
    shere New Member
    Brilliant, thanks. I wasnt sure if I had to remove some of the fairings to take the cover off.
    Ta!
  6. Kentblade
    Kentblade God Like
    I take it you mean the 2 little metal collars that stop the rubber spacer from distorting when you tighten the bolt....yep lost them before :mad:
  7. Slick
    Slick Elite Member
    LOL that's them, lost mine for months only to refind it under the air duct!
