Removing the Standard Exhaust - Full System including headers
Discussion in 'Mods, Upgrades, Accessories and Products' started by samuk, Jun 25, 2012.
  1. samuk
    samuk Well-Known Member
    So i have 2 bikes, a Red RR5 has a full Akra system, the Repsol RR5 has a standard system. I want to be able to swap these over quickly - hopefully over 2 evenings.
    So:
    1. Take off the Full Akra System from my Red bike
    2. Take off the Full system from my repsol RR5
    3. Put the Akra System onto the Repsol
    4. Put the standard exhaust on to the Red RR5
    Any pointers? before i start tommrow?
    I was told the standard Exhaust has a valve in it that is attached to the throttle - what happens to this on the Respol when i attach the Akra? and ont he Red Rr5
    Anyone looking for something to do, feel free to come over to give me a hand.. ;-)
    #1 samuk, Jun 25, 2012
  2. scooby
    scooby Elite Member
    it's a alot easier to get the headers if you remove the rad,but not essential.
    if you go onto the akky home site,it has a schematic diagram+and a fitting instruction file on PDF,shows you how to remove the standard kit aswell.
    http://www.akrapovic.com/en/Motorcycle/Products/Pages/Product.aspx?BrandId=7eb20b7b-271c-47b2-b9ab-b3c94fbe56e4&ModelId=ceca35e8-0ff4-4656-bd3f-ddd65a7b0b40&ModelYearId=cb449dbd-d7ac-40b0-921d-e7d71ab56bc7&ProductId=2141&ProductFilter=Active&DisplayName=Honda CBR+1000+RR+ S-H10R5L-HWC+Racing+Line+(Carbon)
  3. samuk
    Just noticed the PDFs on this link..thanks
  4. samuk
  5. ray
    ray Well-Known Member
    At least with the RR5 you shouldn't have to worry about the O2 sensor in the headers :)
    In order to undo the headers you don't need to remove the radiator, but you do need to displace it to give yourself some room. It's also worth putting a bit of card on the back of the radiator whilst working, to stop you skinning knuckles :D
    Don't forget to buy new gaskets for the headers.
    Don't remember anything in the exhaust attached to the throttle, but will have the servo flapper in the end can. If you look on your red RR5, you'll probably find two loose cables tucked up somewhere. These need to be attached to the servo in the original exhaust. Can't remember the procedure, but the servo has to be set to a particular setting.
    Hope I've helped :)
  6. ray
    Also Haynes manuals can be invaluable sometimes ;)
  7. samuk
    Thanks Ray,
    The Gaskits, are these for the headers? is it just one gaskit per bike?
    Will get these ordered today..
  8. samuk
  9. ray
    You need a gasket for each head mate, so four gaskets per bike.
    Make sure you drown the header nuts in WD40 or similar anti-seizing fluid.
    There is also a gasket at the other end of the headers that goes into the link pipe, but if you're replacing the whole system you should get away with using the original.
  10. samuk
    any idea if i can mail order the gaskets from anywhere?
  11. ray
  12. ray
  13. samuk
    Ray, I dont spouse you fancy coming down to Loughton one day.. ;-)
  14. ray
    Lol, you'll be fine mate.
    Just take your time and if it helps take plenty of photos for later reference.
    Trust me mate, if I can do it you'll be fine :)
    As I said before, if you can get hold of a Haynes manual, they are helpful.
  15. samuk
    Will i definitely need new gaskets? or could i use my old ones?
    Costing £6 each - 1 weeks delivery
  16. ray
    I knew they weren't cheap as I replaced them all on mine when I fitted a set of US original headers.
    Have you tried Cox Honda in the Traders section for a price?
    I can't see anything on the Akra instructions about the header gaskets/sealing rings.
    But in the trusty Haynes manual:
    'Remove the sealing ring from each port in the cylinder head and discard as new ones must be used'.
    'In order to help with fitment, dab each new sealing ring with a small amount of grease to hold them in position'.
    It's entirely up to you mate, but what I didn't want when doing mine, was to put it all back together and have the headers blowing :)
  17. rocket
    rocket Active Member
    when i,ve changed full systems on my own bikes i don,t replace the gaskets. just make sure they don,t fall out without you noticing. make sure your socket is a damn good fit on the 8 header nuts before you trying undoing them. the cable on the silencer link pipe is easy just make sure the pulley on the servo motor is back in its original place after youve removed the cables from link pipe before you switch ignition on. so check pulley position under riders seat just before you start to disconnect them. its all straight forward buddy just don,t rush it if your unsure.
  18. scooby
    scooby Elite Member
    pretty sure the akky systems dont use gaskets,taken mine off rr5 a lot and just fitted an akky to my 09,no gaskets.
    the header bolts only need to be torqued upto about 9 or 10 ft/lb.it's the springs that do most of the retaining
  19. samuk
    Took the akra system of the red bike today - took all of 1.5 hours..
    The radiator did not need moving though helped little..
    Hoping to get this on my bike Friday evening...;-)
