Replacement fixings for fairings
Discussion in 'Racing & Bike Sport' started by Graham, Dec 3, 2019.
  1. Graham
    Graham New Member
    Hi I'm trying to find replacement fixings for my RR5. I need to replace some of the threaded grommets that hold two panels together - like a regular open grommet that sits in one panel but with a threaded metal insert to take a bolt thro the other panel. Any suggestions would be appreciated! Thanks
  2. Barstewardsquad
    They are called well nuts, readily available in fleabay etc.
    Probably worth also getting some of the plastic push pins/rivets, the ones with the screw head and the plain push ones.
  3. LRJimmy
    LRJimmy Active Member
