Repsol blade tall screen
Discussion in 'General 1000RR Discussion' started by Knighster, Oct 27, 2014.
  1. Knighster
    Knighster New Member
    Hi dudes,
    Just introduced myself on the newbie section and wanted to ask first of all if anyone knows where to get the repsol smoked taller factory screen best place?
    Also read a bit on fitting as heard is a bit of a pain in the crotch so decided to remove my standard screen and put it back on as a little bit of practice (yes I was a bit bored). Blimey it's a bit of a fiddle. I did notice that the previous owner has had another screen on at some point as the left hand tab has already been snapped. I loosened the mirror nuts so the front fairing was more flexible and carefully Pressed down the front of the screen to clear the lone tab whilst maneuvered in a backwards motion to get the screen out. It looks like the tab holds the screen in place rather than secures it? The screen seems solid with only one tab. I put the screen back without too much issue being careful of the dreaded tab so should the dark taller screen be installed in the same manner? I'm probably being paranoid!
