after changing my air filter and going for a run bike cut out ive got lights but no fuel pump ive been told on here it maybe the tipping switch but unsure how to check or reset,please help thanks
I would firstly go back and check the 2 plug connectors under the tank to make sure non have been dislodged when re-seating the tank, things are tight under there and breather pipes and plug connectors can easily be unsettled also watch you haven't crimped any fuel lines. The tip/tilt sensor is in the nose cone so wouldn't have thought it would be that if youv'e only changed the air filter.
+1 on squeezing the fuel line under the tank. I did that 1st time a lifted the tank and the forum helped me untrap it. Never done it since
