Right hand bar end stuck
Discussion in 'General 1000RR Discussion' started by rollsroyce, Jul 17, 2013.
  1. rollsroyce
    rollsroyce Member
    HI i have got some new heavyweight bar ends on order, the problem i have is that the r-hand bar end wont come of, it is a fancy glorified washer with a philips head on the end, the problem is that the bloody screw just goes round and round,it appears the internals are turning inside of the clip on, i dont care about buggering up the end, i just want the dam thing out, so i can replace, cheers rolls
  2. martinowen
    I had a similar issue with mine I tried 3 things but can't remember which one worked
    1- push end in while unscrewing
    2- pull end out
    3- push downwards on the end and unscrew ( forcing the screw head down ) hope that makes sense
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Hold the actual bar end still and unscrew. the bar end slots onto internal with grooves
  4. Barstewardsquad
    If none of the above works roll back the grip and you should see a hole in the bar. Shove a screwdriver in the hole and keep it pressed in there whilst you try and unscrew the bar end.
  5. Pete H
    Pete H Active Member
    Obviously try those things first, but............
  6. rollsroyce
    rollsroyce Member
    i think it is all bloody going round inside the bar,(i can feel it)i have loosened the twistgrip but it doesnt pull out far enough, so looks like i will have to undo the throttle cables so i can detach the grip, what a bloody carry on. i (dremelled) off the washer/bar end and now have only a screw, going into the bar. will attack it tomorrow.
  7. coupe312
    coupe312 Active Member
    if in doubt drill it out
  8. rollsroyce
    rollsroyce Member
    well brute force and ignorance won the day, i ripped it out with mole grips, as i dint want to piss about taking the throttle cables apart, if no one has taken out the complete crap before,( i dont know why they have a system like a rawlbolt) it is a long bar with a serated rubber (cog like) washers at both ends, with a metal spring, clip bar end side with two metal spikes, i imagine that is what holds it all in place, (they are now flat) lol, just waiting for snail mail to deliver two heavy duty bar ends.
  9. Muffking
    Mine just spin round & round. Are they meant to? As i have RR bar ends and one always ends up facing down :eek:
