Road 5 to m7rr
Discussion in 'Mods, Upgrades, Accessories and Products' started by raphael, Dec 16, 2019.
  1. raphael
    raphael Elite Member
    anyone gone from using the pilot road 5’s to the m7rr?
    My new bike has he Metzeler on and are brand new but I’ve always had/put Michelin’s on my bikes.
    Any tips on what to expect, quick to warm up, softer carcass(prefer the harder Michelin’s) rough mileage? Are they a more sporty dry weather tyre?any input would be helpful as will need to get a set before Xmas otherwise
    Cheers
  2. Barstewardsquad
    Not had them in the rain but they are really good in the dry.
  3. tuktuk
    tuktuk Elite Member
    M7rr are a brilliant all rounder. You could hammer it round a dry track then ride it home in the pissing rain.
    High silica content in the compound gives good wet grip from the off.
    As a road tyre you cant go wrong
  4. dmc12
    dmc12 Well-Known Member
    If you can hang on there's a new M9RR coming out soon - it was revealed at EICMA. Depends how soon you need new tyres!
  5. raphael
    Thanks mate but I’m not sure I want the m7’s that are on there as always used the pilot road 5,s and ideally looking for a comparison.
  6. Si.
    M7rr best tyre I’ve used, mate. Crank it right over in the rain and stick like glue in the dry...
  7. Shutty
    Shutty Well-Known Member
    Always put M7’s on my Blades
    i took the Dunflops off when brand new to replace with Metzlers
    i dont even consider another tyre, pretty instant grip, great in rain and cant fault when hot.
    id be going the other way taking the Michelins off
  8. bazzashadow
    bazzashadow Elite Member
    I have these fitted and warm up a lot quicker than the b21’s I had on but I’m not sure if it me or the tyres but I feel they track a lot
  9. tuktuk
    tuktuk Elite Member
    What pressures you using bazza?
  10. bazzashadow
  11. Lozzy
    They shouldn't feel like that Bazza...I must have had 10+ sets of them up to now and they're superb in most conditions as others have said. I run anything between 36/36 and 36/40...sometimes in summer they've dropped to 33/33 and they run great at all these pressures. I'd get the wheels off and give it all a good check over if I were you.
  12. nigelrb
    :eek::eek::eek: 10 sets!!
    That would be the best recommendation anyone could get for tyres.
    I'll defo use them on my next tyre change - I think the 954 will love them instead of my usual Pirelli Rosso IIs. Then I will evaluate whether to use them instead of Super Corsas - which I really love.
  13. bazzashadow
    Your never do the miles for one set Nigel let alone ten sets;):p:p:D:p:p
  14. nigelrb
    True, and that is a problem with multiple bikes because tyres go off before they're even half worn!:rolleyes:
