rr04/05 vs 06/07
Discussion in 'General 1000RR Discussion' started by tazmania_1981, Mar 5, 2015.
  1. tazmania_1981
    tazmania_1981 Active Member
    Hi guys
    Can someone would be able answer my questions
    is the rr04 radiator same size as the rr06
    I need 04 but can not find from a UK seller but there is one 06 model brand new only for £140
    I will love you forever of you can tell Me if rr06 would fit to rr04 or not??
  2. Blade048
    Blade048 Active Member
    I've got a feeling they're different mate. Think the 06 is slightly bigger. Not 100% though, sure someone will be along to put you straight.
  3. arthurbikemad
    Yes they are different sorry to say.
  4. Dave
    Dave Member
    Agree with the guys they are different but anything can be made to fit.
  5. FirebladeRR
    FirebladeRR Active Member
    They are indeed different but it's actually the 04-05 is bigger than the 06-07. You can swap them easy enough. You just need to make/weld a bracket to the side of the 06-07 to hold your overflow bottle and route some tubing ;) You also will need a longer bracket to support the bottom of the rad.
  6. tazmania_1981
    Thank you gus if smaller anything can be done
    great staff :))
  7. martinowen
    I prob need to fit a smaller one soon for my fairing change so will keep an eye on this if you don't mind letting us know what had to be done to fit it
