RR4 Rectifier Problem
Discussion in 'General 1000RR Discussion' started by Fireblade Addict, Jan 14, 2017.
  1. Fireblade Addict
    Fireblade Addict New Member
    i think the rectifier has failed on my RR4. Could someone please tell me where it is located so I can replace it please?
    Thanks
  2. Muffking
    Behind the upper left (near side) side fairing panel.
    You can test it to be sure.
  3. tazmania_1981
    tazmania_1981 Active Member
    Brighton weemoto do a Electrlux replacment little more expensive but last long time and also come with warranty.
  4. Haggler ®™
    Haggler ®™ Active Member
    However due to it being an 04 model it,ll be more likely to want a modified flywheel and stator windings as historically the windings burn out taking the rectifier with it
  5. Iain
    Iain Active Member
    Given that the RR4 has a known problem with the stator, I would advise that you check thoroughly before you buy anything.
  6. dansp1
    dansp1 Active Member
