RR5, Fairing and exhaust issues?
Discussion in 'General 1000RR Discussion' started by Hedges, Jan 10, 2016.
  1. Hedges
    Hedges Active Member
    Hi Guys,
    Fitted my new fairing to the blade today, all OEM which had been resprayed!
    Previously i had Jap Crap, all the fairing had melted on the belly, thought it was due to poor fit and generally poor plastics however it appears it must be something else, after fitting the fairing today the exhaust is touching the left lower belly pan?????
    Ive fitted heat reflective padding, after sparking the bike up for a while the belly pan was almost too hot to touch :(
    Is it right for the left belly pan to be so close to the exhaust?
    Anyone got any advice?
    Thanks
    Scott
    #1 Hedges, Jan 10, 2016
  2. SimonRR
    SimonRR God Like
    Does it have the OEM honda exhaust?
  3. Hedges
    Yep, standard exhaust!
  4. derchef
    derchef Well-Known Member
    2-3 pictures were not bad ...
  5. Hedges
    Sorry the best pic i could get...
  6. Hedges
    Would anyone recommend exhaust heat wrap?
  7. SimonRR
    SimonRR God Like
    NO not if its touching the fairing as it will still melt it, there needs to be a gap so that the hot air can flow away while riding, I always thought?
  8. SimonRR
    SimonRR God Like
    mine comes close to touching the fairing on the left side too but there is a gap, not sure if that heat shield is to think also, the its meant to reflect heat i thick, and still needs a gap, might best with thinner shield?
  9. Hedges
    Yeah i think your right mate ..... think ill search for a thinner heat shield! thanks
  10. derchef
    it s really close!
  11. martinowen
    Standard fairing has a thin piece of metal, like a plaque on a trophy if I remember correctly
  12. SimonRR
    SimonRR God Like
    yeah looks like thin Aluminium foil, but only about 5x3" if that, and very thin :D
  13. Dave
    Dave Member
    We use self adhesive aluminium foil on vulnerable areas, about as thick as heavy kitchen foil, if you want some pm your address and i'll get some in the post to you.;)
  14. Hedges
    Nice one Dave, top man!
