RR5 Front Brake Master Cylinder
Discussion in 'Maintenance' started by wilbert, Feb 6, 2016.
  1. wilbert
    wilbert Active Member
    The front master cylinder is on its way out. Do I strip and repair or put a new unit on? Also been told to look for an 18mm kit and bore out the original housing to get much stronger brakes. Anyone else done this? If so what tolerance on the bore?
