Hi. Have bought new wiring loom for my 2006 blade. Am half way though installing it but have a question. Can anyone tell me what side of the bike does the wiring that goes to the headlight run? (Ie the 21 pin connector) The bike was modified so that part was missing hence the need for the new loom. If anyone has some pics of their 06/07 model with nose cone removed it would be most helpful and appreciated. Thanks in advance.
left WIRE HARNESS (CBR1000RR6/7) - CBR 1000 RR FIREBLADE CBR1000RR6 2006 EK - CBR1000RR6 - Sale Honda motorcycle spare parts microfiche origin
Thanks. Photo would be good as i am trying to work out where the loom with 21 pin and other big connectors are routed. Above the frame on left hand side or under the frame by idle adjuster to front? Have nothing to go on as last loom was cut and looped back on itself. Thanks guys.
Well getting there I think. Has any one please got a photo of this left side inner fairing panel that holds all the big wiring connectors. Found this video on YouTube but not quite clear enough. Trying to work out if the loom with these connectors run to left side of frame and air box or whether it's poked through the frame somewhere?
Do a search, PDF workshop manual is out there and that shows the wiring location. If you cant find it give me a shout can provide a link
hi- link would be really helpful. I have found the manual for 2004-2005 but can't find 06-07 model. Think i have it nearly sussed- have the fuse box and relays in their holders on the left inner fairing with the big grey connector in front of that but can't work out how this connects to headlight/sub wiring loom? Am also stuck on the right side- how the expansion bottle connects to the bike/ inner fairing. Think i might have some brackets missing. If any one has pics of how the inner fairings connect to the bike this would be very helpful to me. thanks
Thanks for that but I think it must be different on my 06? If you look at the picture of the bike above (not mine) the fuse box and relays are in plastic holders on inner fairing on left side of the bike. The 21 pin connector wants to go straight on but I can't work out how this then connects to the multi plug of the headlight.
Thanks for putting pics up. Yours is definitely different to mine though. If you look at wiring looms 04-05 and 06-07
