RR7 brakes on a RR5??
Discussion in 'General 1000RR Discussion' started by Steveid102, Jul 17, 2013.
  1. Steveid102
    Steveid102 New Member
    Hi all, just a quick question...I own a rr5 n got the chance to get some secondhand but like new wavey dics from a rr7, so I'm just wondering are the same n will they go straight on?
    Cheers for any help guys :)
  2. 1000rrboyjay
    1000rrboyjay Active Member
    they are very similar, but the front disc is 10mm larger, I thought the calipers were the same but not sure if disc's will go straight on. The wheels are the same though. I'll ask my honda dealer your question...
  3. martinowen
    Need 5mm spacers as 310mm on rr5 and 320mm on 6/7
  4. Steveid102
    Thanks for your reply :) not to sound to thick but where and how do I get these spacers? Also I forgot to say I can get the rear to.....is this the same??
    Cheers Ste
  5. martinowen
    I think the rear is the same on both models, the spacers you need is just a 5mm thick washer basically. Should find them on eBay with a search for 5mm calliper spacer
  6. Steveid102
    If its just a 5mm spacer n longer bolt I might be able to source them from work. Cheers for your advise.
  7. martinowen
    Currently looking for discs myself :) so if you change your mind let me know :D
