RR8 Fork Dimensions
Discussion in 'Mods, Upgrades, Accessories and Products' started by BladeRR8, Jan 26, 2012.
  1. BladeRR8
    BladeRR8 Active Member
    CastrolCraig has got me thinking seriously hard about dropping an RR8 front end into my SP2 and as I have'nt got access to my bike at the minute I was wondering if somebody could do me a favour.
    What are the diameters of the RR8 fork at the upper and lower triple clamp ? From internet searching I think they are 50mm & 54mm respectively but if someone could check on their actual bike it would be much appreciated.
    Cheers for any help that can be offered :D
  2. CastrolCraig
    CastrolCraig Active Member
    It's def. 50mm at the top.
  3. BladeRR8
    Cheers Craig I was pretty sure it was 50mm at the top it was the bottom being 54mm I was not sure about any chance of having a look mate ?
    Thanks if you can help no problems if you can't I know its a bit of a hassle.
  4. Bats
    Bats Active Member
    Just seen this will check tomoz for ya!!
  5. BladeRR8
    Cheers Bats
  6. Bats
    Bats Active Member
    hi mate ive just been and dont it bit hard without taking forks or fairing off lol!
    I managed and get 54mm poss 55??
  7. BladeRR8
    Great I suspected 54mm just needed it confirming. Really appreciate it Bats thanks dude your a star.
  8. Bats
    Bats Active Member
    No probs man ;)
  9. Shameless
    Shameless Active Member
    Honda CBR1000rr8 fireblade 56mm alloy race clipons ebay item number 150566542996
    Im not saying it isnt 54mm.
    NEW
  10. Bats
    Bats Active Member
    I did say 54-55 ish ;)
  11. BladeRR8
    Thanks Bats & Shamless all comments are much appreciated.
    I personally think the ebay guy is wrong with the 56mm dimension and as he is only a breaker I would'nt take his comments as fact personally. Thanks for the comment and help though Shameless.
    The top dimension for the SP2 fork is definitely 50mm (see attached Harris size chart) the bottom dimension which Bats measured for me is I m confident 54mm as A, Bats physically measured it B, most japanese bike forks are 50/54. And if the diameter at the top of the fork was 56mm as the ebay breaker suggests it would never pass through the bottom triple clamp which is 54mm.
    Thanks again for all your help guys.
    http://www.harris-performance.com/acatalog/Handlebar size chart.pdf
  12. Shameless
    I had to go out to the garage and check, tops are 50mm and lower is 54mm, checked with callipers. Checked a spare 05 front leg I have and that is the same.
  13. BladeRR8
    Thanks again Shameless mate, sorry if I got you so worked up you had to check.
  14. Shameless
    No problem, Hope the transplant works out
