hi all Can anyone identify the type of connector plug Honda use for the brake light? This is a white 3 pin plug that comes pre fitted to the OEM brake light, but I'm after a connector to fit an aftermarket part without modifying my original loom. Please help as I have failed to make progress after several hours on Google! Chris
How about using this as its a sub loom if I recall http://www.ebay.co.uk/itm/HONDA-CBR...hash=item2c7858cc0f:m:m08VmcyI7tfyj2-LxqQ6VmA
Thanks for sharing that. I don't recognise the part from the picture but I'm guessing this is the part of the loom the plug on the stock brake light plugs into, which must plug in somewhere under the tank etc. That would definitely work, although at £20 I might be able to buy a used brake light just to buy the connector and wiring. Thanks again.
