RR9 engine rattle
Discussion in 'General 1000RR Discussion' started by allbutt55, Jun 26, 2014.
  1. allbutt55
    allbutt55 Member
    I have been looking though the forum with no luck my RR9 has just started to rattle you can hear it at idle to about 5k revs sounds like a loose timing chain it's not clutch as it don't make any difference if it's pulled or in gear etc do the suffer with any issues?? It's done 12k full dealer history it's still under warranty so not worried about cost
  2. Si.
    CCT ( cam chain tensioner) less than £90 fitted.
  3. allbutt55
    allbutt55 Member
    Going back to dealer today in the van not going to risk riding it :(
  4. allbutt55
    allbutt55 Member
  5. Silverback
    Silverback Member
    I had something similar on my 08 after 38,000 miles. We changed the cam chain tensioner but it didn't help. Various experts suggested that although they could hear the rattle, the engine was working fine and it wasn't going to blow up ! The only other solution was to have the engine out and stripped which would have cost a fortune. The bike was out of warranty so I sold it on Ebay and bought a 2012 bike ! My 08 bike drank a lot of oil from the get go and I personally think the engine just wore to the point that it was making funny noises. The new 2012 bike does not use any oil at all.
    Good luck !
  6. Alblade
    Alblade God Like
    My CCT only needed changing at around 65 - 70k - even after changing at that mileage the engine still rattled a bit, not much mind and the engine has almost zero wear at 80k
  7. allbutt55
    allbutt55 Member
    Well bit of an update honda dealer has taken the clutch basket out and they think it's that so they have ordered a complete new clutch and will test after??
    Do fireblades suffer with clutch issues??
  8. zebeddy72
    zebeddy72 New Member
    It's a Honda, from having had one before they always rattle :)
  9. Silverback
    Silverback Member
    There was a recall on the clutches on the 08 bikes. Never had a problem with mine but Honda changed it anyway.
  10. allbutt55
    allbutt55 Member
    Well dealer just called they think its clutch springs loose???? which i said how can it be that as when you pull the clutch in it still rattles??
    they have order new springs and a basket!!
  11. Mike07
    Mike07 Active Member
    I would be tugging the leash.
    ........ Mike.
  12. allbutt55
    allbutt55 Member
    Well they changed the clutch basket and it's better but still making the noise :( any ideas?
