RR9 Fairing Removal
Discussion in 'General 1000RR Discussion' started by rewy..rr, Aug 29, 2016.
  1. rewy..rr
    rewy..rr Active Member
    Anyone got any info/advice about removing side fairings from RR9, Ive not attempted it before as understand its a pig of a job to do.
    Just want to give the insides/downpipes and motor a clean.
  2. blake7
    blake7 Active Member
  3. sps170373
    Just take your time and take a step back if you get frustrated with anything!
    Worth doing the airtube flapper mod while you have the sides off as makes it easy to remove the panels next time
  4. RepsolSam
    RepsolSam Well-Known Member
    Thats what i found too...but its not that much of a job...
    1st time everything is difficult...but after you have done it once..it take 10 - 15mins a side.
    Good luck
