Running In
Discussion in 'General 1000RR Discussion' started by abv, May 10, 2011.
  1. abv
    abv Active Member
  2. flatstickHRC
    flatstickHRC Active Member
    i rode mine like i normally would from day one. obviously took it easy on the brakes for fors 50 miles to bed them in etc
    only thing i didnt do was hold full throttle or redline it until it had its oil change. otherwise just enjoyed it
    also let the bike heat up till the fan cam on and allowed to cool and repeated a couple of times. heard that seals the piston rings better.
    the engine feels better every time i ride it. now has 1300+ miles so should be well run in now
  3. flatstickHRC
    oh one more thing - i found my chain stretched alot in places and was tight in others
    adjust your chain every 100 miles or so for the first few hundred miles and make sure you check for tight spots
    mine had a massive tight spot but it seems to have gone now.
  4. JM1
    JM1 Active Member
    Good advice :Banane40:
  5. Brym
    Brym Active Member
    Fowlers mentioned keeping the revs below about 6k ish to me most of the time but Honda don't list anything specific in the manual
    Basically not to go revving the hell out of it everwhere but equally you don't want to be to gentle with it either as the piston rings need some load on them to bed in properly. Try and work up & down the gears/revs i.e. on nice bendy roads and not labour the engine to much i.e. sat on the motorway at steady rpm and try to avoid short journeys where the engine will not get upto temperature properly until bedded in.
