SC59 electrical problem
Discussion in 'General 1000RR Discussion' started by Gixxa84, Apr 17, 2019.
  1. Gixxa84
    Gixxa84 Active Member
    Dear all,
    I have a problem with my charging circuit on my 2009 CBR1000RR. I have 14.2volts DC going to the battery when the engine is running but it seems also 30.1volts AC. I originally thought rectifier so have purchased a new one and fitted this. I have also checked the alternator charging resistance and the maximum is 0.8ohms which is I believe in specification. There is also is continuity to all yellow wires on connector 3p and no continuity to ground.
    Any Ideas?
  2. Slick
    Slick Elite Member
    What are your symptoms, flat battery?
