Scorpion RP1 touches swingarm
Discussion in 'Mods, Upgrades, Accessories and Products' started by Trouge, Apr 3, 2015.
  1. Trouge
    Trouge New Member
    Hi guys
    I've just bought and fitted a new scorpion rp1 can to my rr8 and am pleased with sound but the can is touching my swingarm with no load on it. I've followed instructions to the letter and all bolts and fasteners line up as they should but I'm concerned that I'll scratch the swingarm with the can. Any ideas?
    Thanks
  2. barry107
    barry107 Active Member
    I had a similiar issue with my Arrow can, I placed a couple of thin washers between the frame and right rearset. This spaced the rearset and the exhaust as the fixing strap is fixed through the bottom of the rearset.
  3. RRoss
    RRoss Active Member
    I've got the scorpion can on a '12 and no issues. Could it be the angle the primary silencer sits at,can it be rotated slightly?
  4. Trouge
    Trouge New Member
    Thanks for the replies.
    If I rotate the primary silencer the mounting bolt won't line up will it? How big a gap do you have between can and swingarm when on side stand and did you torque bolts or hand tighten. Sorry for all questions!
  5. RRoss
    RRoss Active Member
    Mine was fitted at the dealers when i bought the bike. I'll take some photos and post tomorrow,am sure theres about a 1cm gap as i slip a wash mitt over the exhaust to stop water going down it when i clean the bike.
  6. Trouge
    Trouge New Member
    Magic thanks
  7. ccr32
    ccr32 Active Member
    The Akrapovic I have just fitted to mine came with a couple of 5mm spacers to fit between the RH rear set and the frame, which ensures the can is far enough away from and not touching the swingarm. Would recommend trying the same, or fiddling with the primary silencer / can positioning as has already been suggested.
  8. Cbrjay
    Cbrjay Well-Known Member
    I had to put 2 more washer behind mine after fitting Gilles rear sets
  9. RRoss
    RRoss Active Member
  10. Dave
    Dave Member
    Possibly rotate the can and alter the angle of the mounting bracket.;)
  11. Trouge
    Trouge New Member
    Thanks guys and especially RRoss for the pics. Just needed to loosen bolts, rotate and tighten. Now she's sorted!
  12. callumw
    callumw Active Member
    My Akra sits really close to the swingarm with no load (about 1-3mm). I'm ok with it like that, but put a strip of ventureguard on the swingarm at the possible contact point just to be sure.
    A year or so on and I can see no marks on the ventureguard or the can.
  13. ccr32
    ccr32 Active Member
    That's good to know. Mine is the same but no signs of it having actually touched it as yet.
