scottoiler and flapper mod
Discussion in 'Mods, Upgrades, Accessories and Products' started by cliffbarrimore, Mar 29, 2014.
  1. cliffbarrimore
    cliffbarrimore New Member
    hey all
    I am sure the topic of intake flapper has been done to death....BUT mine seems different
    I have a 2011 version, it says cbr1000rrR8 on the frame
    if I look down the intake tubes I can see a flap and with the engine off its down, not checked with engine running and in gear....
    Now what I wanted to do was pull off the vacuum tube and use it for my scottoiler, but when I look through the left side of the bike I see one tube and some wires.. I have tried to follow the tube without stripping the bike and one way it goes up to a black plastic box under the head light and the other way disappears into the engine compartment somewhere,
    So I am not sure what hose I am looking for, I cant see the box under the light is connected to the flappers at all.
    Is mine somehow different, being a New Zealand Model...cant see that it is, but I also cant see any metal diaphragm, etc
    Which is the best way to go, tank cover off or side faring off,
    thanks
    Cliff
  2. sps170373
    Diaphragm would be underneath I believe, flaps don't open until 4000rpm
    Wouldn't it be easier to just buy a new tube for your scottoiler?
  3. Slick
    Slick Elite Member
    I think the diaphragm is on the right air duct. It is accessed by removing the upper inner cover and duct cover
  4. sps170373
  5. cliffbarrimore
    Ah, ok thanks for the pictures, what I had seen on the www was reach in grab the tube, pull it off and plug it, I thought rather than plug the vacuum feed, I could use it for activating the scottoiler.
    so looking at the pictures, its a little different than the slightly older models as most www posts show a single flap etc...
    I may just leave it a tag my scott oiler else where on the vacuum system.... any suggestions? especially if I don't need to strip too much off..
    thanks
