Scratch on my speedo!!!!!
Discussion in 'General 1000RR Discussion' started by ufoxed, Apr 11, 2018.
  1. ufoxed
    ufoxed Active Member
    Hi guys I have a light scratch on the plastic lens face of my speedo and it pisses me off loads don't know if it was done by some twat or this old twat but don't remember doing it,...Question I can get some thing to rub it out or can I get a replacement lens?....has anyone here ever changed one before as it doesn't look easy. I need to resolve this or
    Other wise I shall NOT look at my speedo!!!!!!!!!!!!!!!!!!
    Cheers guys
  2. NBB
    NBB Active Member
    Depends how deep it is mate. Have you any pics we can look at without hurting your eyes?
  3. Ian63
    Ian63 Active Member
    There was an “old wives trick” using toothpaste to remove scratches from watch face glass. That might work but not sure if you use with a damp cloth too
  4. CBRGav
    CBRGav Active Member
    Headlight repair kits should do it, pretty much a wet sand and cutting compound. fetches the hazing and scratches out of plastic headlight lenses so should work on a Speedo face. If its light enough just try cutting compound on it first if you've got any
  5. bradt
    bradt Elite Member
    Will be interested to see if any of the suggestions work I have the same problem on my clear plastic.
    #5 bradt, Apr 12, 2018
  6. CBRGav
    The see through plastic bit should I'm 99%definite as I did my screen from the fairing.
  7. cronester
    cronester Active Member
  8. nigelrb
    Damn @Ian63 . Now I'm wondering if this Quixx product is actually Colgate repackaged!:D
    Good posting though, @cronester, because it might be worthwhile testing on fairing screens. The associated video is worth a look too:
    https://www.quixx.com/en/products/repair-products/acrylic-scratch-remover/videos/
    Available on ebay for 8.50: https://www.ebay.co.uk/itm/QUIXX-Xe...425483&hash=item1a238b87cd:g:h3gAAOSwKQ9aCpJ6
