Scrubbing in new tyres
Discussion in 'General 1000RR Discussion' started by steve750, Nov 1, 2015.
  1. steve750
    steve750 Active Member
    Hi guys!
    Finally managed to get out on the bike earlier with a mixture of mainly dry and damp roads.
    Tyres felt great but the new shiny rubber was always in the back of my head!
    How many miles realistically should I do before I can push it a little?
    Cheers
  2. Philp10
    Philp10 Member
    All depends how u ride. Took me 20 miles today. Build up slowly.
  3. MPJ
    MPJ Active Member
    Just had new boots fitted myself, asked the same question and Powerlinks shop boss told me 75 very careful miles. He knows I'm a rookie though.
  4. Slick
    Slick Elite Member
    never thought twice about new tyres, rode them gently for about fifty miles leaning a little more each time. That is until last year when highside on newish tyres, problem was the weather was shite during the run in so didn't really get them to the edges even after 100 miles, bad road surface didn't help much either
    Wondering if there is more mechanical way to scrub them ie combo of tyre warmers and belt sander!
  5. steve750
    Yes, I've always wondered if there was a way to get rid of that sheen! Hot sunny days are great but dull dampish days are not ideal!
  6. MPJ
    MPJ Active Member
    Great. I was going to try and do mine tomorrow !
  7. Wozza
    Wozza Elite Member
    Stay off A roads that may hold the damp head for a dual carriageway
    Or motorway with good exit slip roads then go up and down gradually leaning further the heat from the straight
    Run should hold you when you get to the bends but gentle on the throttle not a big handful
  8. Lozzy
    I get new tyres about every 4 months & regardless of time of year I do a steady 100 on them up & down the bypass, round & round the roundabouts & a whiz over the peaks...job sorted :)
  9. iang27
    iang27 Active Member
    Paddock stand, rough wet and dry type paper, turn wheel., done.
  10. Lozzy
    Is that from 'Top Tips' in Viz? :D
  11. MPJ
    MPJ Active Member
    Good tips, thanks guys..I'll plan a suitable route (weather permitting)
  12. Stevie_d
    Stevie_d Senior Member
    2 roundabouts , then knee and elbow ont Tarmac
  13. Carl
    Carl Well-Known Member
    These days the tyres are remove from the moulds with compressed air so no relaase agent issued, you do not therefore need to scrub the tyres in just bed them into to rims, they recomend 100 miles but 50 will do fine and the grip is there from the off.
  14. SimonRR
    SimonRR God Like
    I yeah Bedded some in on a trip out with the Carl the other week, nice a steady ;)
  15. Ian J
    Ian J Active Member
    100 miles is just a convenient number that has no real basis; when I was working on the Continent they used to say 100km. Just take it easy at first and then use common sense.
  16. Dutch Phil
    Dutch Phil New Member
    It's heat you need not a number of miles. They will grip if they are warm enough not if the surface has been 'roughed up'.
  17. Remal
    Depends on the condition of the road. if your riding around at this time of year it's going to take longer to scrub in. Wet, cold roads are not good.
    Best set I scrubbed in was in the summer. Went out for a blat over wales when it was hot and dry. used most of the rear within 40 miles. And felt planted after around 20 miles.
    But have done the same in the past when it was wet and cold and took over 100 miles as I personally did not feel that confidant on new tires in through conditions.
