Seat Removal Help (To get to the Battery)
Discussion in 'General 1000RR Discussion' started by Alfie, Feb 10, 2012.
  1. Alfie
    Alfie Active Member
    Hi people, just want to know how to get to the battery on the 2011 Blade? I think you pop off the plastic triangles under the seat, is this right? :confused::confused:
    If anyone has any tips I would be greatful
  2. Villan
    Villan Active Member
    Yes mate prise the plastic triangles off, they are just a pop stud, then all will become clear :)
  3. Alfie
    Alfie Active Member
    Is it best popping off from the front or back mate?
  4. Jamiestrada
    from the back, the thickest part reach behind and pull outwards it will pop off, then remove it from the tab at the front, then undo the two screws holding the seat, one either side furthest back :)
  5. Fletch
    Fletch Active Member
    #5 Fletch, Feb 10, 2012
  6. Alfie
    Alfie Active Member
    Thanks a lot guys that help's me in a big way :D
  7. zeepony
    zeepony Active Member
    Is it just me or did anyone else loosen the fuel tank bolts first before realizing the seat screws are the ones next to it?!
  8. Jamiestrada
    I will admit to that one lol
  9. Nutty Tart
    Nutty Tart Well-Known Member
    DOH !!!! numpties ... as if anyone would do that .......................... :eek:
  10. Benn The Pig
    Yes as from where I was stood I couldn't see the seat ones as they are recessed lol
  11. Alfie
    Alfie Active Member
    Right thats the seat been removed so thanks guys for that its quite easy when you get the hang of it! ;)
  12. rocket
    rocket Active Member
    and me. took them out and still no luck with seat coming off!! the seat screws are fiddly buggers as even when undone they still just sit in the hole. had to hook something under screw head to pull out.
  13. Nutty Tart
    They can be little buggers can't they
    I have changed mine for Ti taper head jobbies ... they are easier to grab
  14. yorkshiregooner
    yorkshiregooner Active Member
    Just wait till you want to remove the pillion hangers lol
  15. Nutty Tart
    Hahaha .... play nice with the noobies YG :D
