Seat screw... > : (
Discussion in 'Maintenance' started by wilko88, Apr 7, 2016.
  1. wilko88
    wilko88 Active Member
    just had to drill out one of the phillips seat screws and I need to find a replacment, would anyone know where I can find another or aftermaret replacement or what anyone else has used instead?
  2. RRoss
    RRoss Active Member
    Hi,hope this helps,it replicates the original Honda bolts just with an easier to use allen head and corrosion free.
    2 x Stainless Steel Socket Cap Bolt M6 x (1.00mm) x 20mm
    2 x Stainless Steel Flat Washer M6 15mm o/d
    2 x Aluminium Collar M6 Thread 8.5mm o/d 5mm length
    2 x Aluminium Collar M6 Thread 8.5mm o/d 3mm length
    Total came to £11.15,all from Probolt:)
  3. wilko88
    Brillient! thank you rross for your intel, will order straight away. :cool:
  4. stevet
    stevet Active Member
    yeah ,ta for sizes rross....mine also a mare to get out
  5. stevet
  6. wilko88
    Like to say a magic thank you to Pro-bolt for there professional customer service & there 10% discount from buying in store.
    Thanks again, RRoss.
  7. sps170373
    Make sure you use copper or moly grease on the bolt it will stop it seizing again! Never had any problem on my original bolt after I greased them both
  8. RRoss
    RRoss Active Member
    Thank god I don't stay close enough to the store,I'd never be out of the place,all that shiny stuff:D
  9. sps170373
    Use competition fasteners, racebolt, projection components and titanclassics for all my titanium stuff much cheaper than pro-bolt and quality is just as good
