Hi guys, does anyone know of a seat sculptor. I have a mate who teaches cbt etc, and has a bike which he just wants a bit of foam taking out of the seat and then recovering, basically just to lower it a tad for the shortarses . Appreciate that the seat will be a little more uncomfortable though. Many thanx
its quite easy to do this yourself, remove the cover carefully and the foam, cut away the underside of the foam that was stuck to the seat pan, doing it this way means you will still have the same shape at the top where the cover fits and you will not be trying to cut a shape, you can cut away the excess with an electric carving knife and a steady hand, or if you don't have one any long bladed knife with a serrated blade will do the trick. ie bread knife or carving knife. when you've cut the desired amount away from the bottom stick it back to the seat pan and refit the cover, take your time removing the cover and this will make refitting easier. Hope this is some help to you.
