Seat Vibration 2008 blade
Discussion in 'General 1000RR Discussion' started by j2112c, Apr 26, 2017.
  1. j2112c
    j2112c New Member
    Can I just ask when your seat is bolted snug with the the two bolts either side of the seat, do you get any movement or does the captured bolt arrangement grip the frame?
    I ask as for years I have had a really bad vibration through the seat starting at 7000 rpm onwards, it is not in the pegs, bars or anywhere else.... so today I noticed the seat had 10-15 mm movement in every direction and the bolts moved relative to the frame.... is this normal?
    I was hoping that the addition of rubber grommets might snug it.... is this a known issue with these blades?
    I remember someone saying they test rode one and found it buzzy... so is it common, is there a solution?
    Many thanks.
  2. blake7
    blake7 Active Member
    Sounds strange, mine is snug with no movement. The seat has a captive nut in it and the bolts should be shoulder ones. Incorrect bolts or captive nut holder damaged?
  3. j2112c
    j2112c New Member
    Ah this in itself helps, that you have no movement.... cheers.
    There does it appear to be any obvious damage...
