security chain fitment question
Discussion in 'General 1000RR Discussion' started by nambiker, Sep 27, 2013.
  1. nambiker
    nambiker Active Member
    hi guys i usually feed my almax chain through the rear wheel into the ground anchor, is there another way to anchor it, so its safer?? they can always take the rear wheel off to take the bike if they had enough time.
  2. Boo634
    Boo634 New Member
    Hi Dont know your situation but my bike is in a car port and I use a Bump stop with a security chain through the front wheel and a chain and anchor on the rear,also the Bump stop holds the bike upright. Boo
  3. arthurbikemad
    Look up on google pinch pin, may help.
  4. nambiker
    that's a good idea! I will invest in one I think
  5. arthurbikemad
    Yep I think so, shame I never thought of it....lol Still like you say a good idea just eye up where you could use it before ordering one.. :)
  6. nambiker
    not many big holes on the blade to be honest. theres a hole in the swing arm that it mag go thru!
  7. Remal
    seen the Pinch pin a while ago and always thought |I should get around to ordering one.
  8. OliN
    OliN New Member
    Had one for my Triumph S3, went through the hollow rear axle, worked well.
    Struggled to find the best place to use it on the Blade though.
