seized link pipe
Discussion in 'Maintenance' started by sps170373, Jul 24, 2015.
  1. sps170373
    Anyone got any advice on how to get a seized link pipe free from an end can?
    Have tried soaking with wd40 and leaving, have also tried heating up and twisting apart! Have a feeling the last owner used an exhaust sealant to hold them together
  2. dansp1
    dansp1 Active Member
    Nylon or hide hammer, bash the joint side on all round, normally works.
  3. sps170373
    Tried that also
  4. exuptoy
    exuptoy Elite Member
    Personally I think WD is shit as a penetrant. Try plus gas or even better if you can get it Krano Kroil. That is the best release oil I have tried.
  5. coupe312
    coupe312 Active Member
    5% niric acid, or Hopes bore cleaner wll desolve the seal?
  6. Mike07
    Mike07 Active Member
    Get it red Hot, with a gas torch if you can.
