Setting up big piston forks
Discussion in 'Mods, Upgrades, Accessories and Products' started by RedMacGregor, Apr 10, 2013.
  1. RedMacGregor
    RedMacGregor Active Member
    Can anyone recommend a suspension company who can setup 2012 big piston forks off a 2012 Fireblade within a 100 mile radius of Birmingham? I fitted a pair of BPF to my 2011 blade over the weekend. They seem to be working quite well on stock settings but I'm sure there is room for further improvement.
    Thanks - Steve
  2. Repsol Rob
    Repsol Rob Elite Member
    Try popping along to local Focused Events or No Limits track day as they usually have special deals by speciasits in that field......recent Donnington day had £65.00 deal to customise and adjust to suit....... obviously helps if you can give feedback to get adjustments made throughout day (but no one needs to know if you take it for a local spin down the road)....
  3. Repsol Rob
    #3 Repsol Rob, Apr 10, 2013
  4. RedMacGregor
    Thanks Rob that's a good idea. I went over to Rockingham twice last year and I know there was a tyre guy there and now you mention it I think a suspension guy. I set my old forks up without too many problems but these BPF are weird.
    BTW where in Worcs are you? Are you a regular on the A44?
  5. Repsol Rob
    Evesham buddy just down the end of your foot path ! ;)
  6. scooby
    scooby Elite Member
    £65? thats a lot.
    phil crowe,parkitt racing an colin@100% suspension do most of the track days and all know thier stuff.£45 for set up,and will work with you throughout the day to get the best settings that suit you.even if your not riding on track,pop down and they will set it up for you.
  7. Repsol Rob
    It might have been the latter...... they had several offers on from memory.....
  8. scooby
    scooby Elite Member
    it's not an offer,thats what it is.
    NL use parkitt racing
    FE use Phil crowe+100%
    not sure about easytrack,and MSV days dont tend to have much service wise.
  9. wedgiewolves#223
    wedgiewolves#223 God Like
    Parkitt racing were at mallory he came and had a look at mine and a chat he told me to have a go see how it felt mine felt planted but it was snowing at Anglesey it felt fine I won't touch it unless I need to I think
  10. samd1985
    samd1985 Active Member
    I found the stock setting for rebound and compression were quite a way off for me personally. Try stiffening up the rebound (turn clockwise) by a couple of turns - you should feel a good difference in that alone. Turn in will feel much quicker and it should hold the line better coming out of corners.
    Give it a go - if you don't like the feel then turn it back to stock
    Sam
  11. RedMacGregor
    Thanks for the info guys - I will have another go myself particularly with the rebound settings. If I'm still not happy it will have to be a track day visit - that is assuming I can get there without being booked for a small number plate, dark visor, noisy exhaust and my tax disc in my wallet!!!!!!!!!!!!!
