shaft to big for her hole! help please
Discussion in 'Mods, Upgrades, Accessories and Products' started by thezipsteruk, May 3, 2013.
  1. thezipsteruk
    thezipsteruk Elite Member
    Good morning peeps
    I bought myself a Sat nav holder (Ultimate add ons Iphone 5 Ram mount and case) Powered Yoke Stem Motorcycle Bike Mount + Waterproof Case for Apple iPhone 5 | eBay
    trying to fit it on so I could go for a ride at the weekend and ITS WONKY!
    The shaft of the ram mount is split diagonally in two so it expands when the nut is tightened, my problem being that it expands so much its impossible to get the shaft to go in straight and it leaves a small gap (for water to eventually rust the insides) as well as looking like some chimp has fitted it.
    I was talking to Sinewave last night and he is going to post picys of his (mount not his shaft hopefully :eek:)
    so...
    has anyone else tried to fit one of these on a 2011 model (dont know if stem hole is larger on this model?)
    I have included pictures so this waffle makes sense, any hints, tips or advice would be most welcome.
  2. megawatt
    megawatt Well-Known Member
    If you can't sort it, I may be able to make you an adapter, if you supply dimensions?
  3. Swiss T
    Swiss T Active Member
  4. Tom68
    Tom68 Active Member
    #4 Tom68, May 3, 2013
  5. coupe312
    coupe312 Active Member
    lube and big weight behind them
  6. sinewave
    Just replied on tother thread but will stick the pix on ere as well.
  7. thezipsteruk
    Thanks to everyone that posted and those that offered help!
    you guys rock, Ive sorted it good and proper.
    and for anyone interested or anyone thinking of buying one for themselves maybe this vid will help.
    check out how staright she is now
