Does the exhaust need removing to install a new shock? - Yoshimura R77 Got a bit of time tomorrow to sort but will leave it for now if the exhaust needs removing as its a ball ache
Yes it does you will not get enough clearance to remove the shock without the exhaust removed, I used two axle stands under the rearsets to support the bike
I know what you mean, easy enough job just cover spring in rags it's a bit of a wiggle job getting the he shock out
Cheers ... will give me a chance to polish the pipes up and sort the linkage out properly I guess ...
2 minute job taking off a racefit exhaust! The real pain is taking out the lambda sensor, count the amount of turns you have to wind back the cable to remove it
