Shorai Lithium Ion Battery
Discussion in 'Mods, Upgrades, Accessories and Products' started by Emywmpb, May 6, 2018.
  1. Emywmpb
    Emywmpb Active Member
    Hi guys,
    Despite jump starting my stock battery last time it died, it is once again totally dead.
    Time for a new one and I like the reviews I see on the Shorai Lithium Ion batteries. Has anybody here bought one, and if so, which supplier did you use?
    Thanks kindly,
    Martin
  2. nigelrb
  3. gaz22
    gaz22 Active Member
    Hi
    From my experience, I use this charger, the good thing about it you can use it on lithium or standard battery using the function buttons on the front so you don’t have to worry about remembering to turn off de-sulphate function for the lithium
    https://www.amazon.co.uk/NOCO-G1100...=1525617328&sr=8-1&keywords=noco+genius+g1100
    As for battery check these
    https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/248790
    If you have an abs bike this is the direct replacement, if it is non abs with the smaller battery this will still fit and give you increased cranking capacity, I have one of these on my 09 track bike and it starts quickly, a lot better than the standard ytz7s battery. This battery has never let me down but saying that it is on my track bike so doesn’t have to do a great deal other than start it
    Hope this helps
  4. bonjo
    bonjo Active Member
    before you spend good money on this battery + charger dosome research and determine if the technology is suitable for your use of the bike.
    Ideal for raing applicions where all year dependability is not required.
    Once you know it ticks the right boxes for you, then consider alternatives too: aliant, shido (also sold under 2 other names). Unlike shorai, their BMS balances the cells so you can use 3rd party charger (suitable for Li off course). Shorai is well established but requires you to use their balancing charger.
  5. tuktuk
    tuktuk Elite Member
    Just put a Shido on mine. Weighs in at 550g or something. Didnt need to charge it or anything, just stuck it in and went.
  6. bonjo
    bonjo Active Member
    Shido is made by a company in china (I believe) also sold under skyrich & JMT names. They are designed to be an easy OEM replacement and the BSM looks after the cell charging and discharging so you don't have to worry . But don't let the battery volt drop a deep diacharge level which is around 12.8v depending on the brand.
    their new range can generate scan codes you can read with your smart phone that gives full status & diagnostics for the battery:eek:
  7. Emywmpb
    +1 for Shido
