Slipper Clutch
Discussion in 'General 1000RR Discussion' started by Givover, Apr 19, 2012.
  1. Givover
    Having had a couple of bikes with the Slipper Clutch i have really never gone down 2/3 gears in one hit, just hard down one at a time with plenty of brakes.Is the down 3 and let the clutch out an option or would it lock up a bit or even worse do some damage .Just curious (In this before you start)lol:confused:
  2. PeterT
    PeterT Active Member
    I sometimes come down 4 gears and drop the clutch, that is what it does, no damage to cause. It should not lock up on dry surfaces but it can slip on white lines and corners that are wet.
  3. Swiss T
    Swiss T Active Member
    I think the oem slipper in my 2010 model is exellent, although I have only used the bike on the road. Having spent most of my time doing track days for the last few years I have become more accustomed to dropping the number of gears required & dropping the clutch; too much going on for me to think about 1 gear at a time. This Blade is smooth as you like; in fact I find it doesn't like any throttle blipping either.
  4. scooby
    scooby Elite Member
    thats what slipper clutches do,allows slip until the rear wheel catches up with the engine speed.different bikes that have them as standard vary quite a bit though,some slip too much,some take a lot to get them to work.
    cant really see the point of them on the road though tbh,but are very usefull on track.
  5. Remal
    Compared to my Speed triple with no slipper and Love them now. I am used to getting a lock of rear lock up's on the triple when enjoying myself on the roads. but the blade does make riding easier
  6. Givover
    Thanks Gents its Lock 'an'load time.
  7. Jamiestrada
    Yeeeee haaaaaa !!!!
  8. BLAGGERS
    BLAGGERS Well-Known Member
    Mamby pamby slipper clutch's......???? Pah, ya need a lock up tear-arsing into bends. Looks way cool and shits everyone up who's following ya. :D
  9. Jamiestrada
    Is that before or after you hit the wall fella :D lol
  10. BLAGGERS
    Big black lines BEFORE. big brown lines AFTER. ;)
  11. Jamiestrada
  12. Givover
    Can we have a riding with Blaggers Thread?
  13. CastrolCraig
    CastrolCraig Active Member
    Mcpint & the TT legends use the standard 09 slipper. If its goo enough for him at the TT it's goo enough for any of us!
