Slow puncture
Discussion in 'General 1000RR Discussion' started by rebel, Jul 22, 2015.
  1. rebel
    rebel Active Member
    How much air would you expect a tyre to lose over a week my back tyre's losing about 3lb slow puncture or about normal
  2. -steves-
    -steves- Active Member
    Up till last weekend mine didn't lose anything over a month, now it loses 33lbs over night :(
  3. RRoss
    RRoss Active Member
    Assuming you're measuring the pressure at same temperature then I would keep a close eye on that tyre as it may indeed be a slow puncture:(
  4. bonjo
    bonjo Active Member
    yes you should keep an eye on it and also give it a close inspection. Look for Slow puncture, leaky valve or rim edge corrosion.
    the rear should change about 2psi over a 10 deg temperature change just to give you some idea.
    TBH I have not experienced pressure loss over time. Only when there is a change in temperature or a problem
  5. bonjo
    bonjo Active Member
