Smooth It Out Suggestions Please
Discussion in 'General 1000RR Discussion' started by Lozzy, Jun 26, 2015.
  1. Lozzy
    Over the last 12k the bikes not as smooth. I know it's not had a re map/power com or been on a dyno. Just spent a lot on it so just looking for the least expensive fix at the mo, and any recommendations for doing it in the south/west Yorks or derbyshire area
  2. -steves-
    -steves- Active Member
    Which bit isn't as smooth, the ride, engine, gearbox? Sounds like you mean engine? Could just be me being dumb as usual :oops::eek:
  3. Lozzy
    Sorry my bad being a bit vague, generally it's hunting and a bit all over the place etc much worse, especially in commute traffic. I've been lazy & got used to it instead of fettling it tbh
  4. Cbrjay
    Cbrjay Well-Known Member
    Where u getting fuel
    From? If supermarket try bp or the like
  5. Lozzy
    Thanks for suggestion but I've tried that & no difference, it's worse in 2nd surging suddenly! It's serviced regular & I maintain it well but this last year it's slowly got worse, I'm averaging 13k a year & things like the oil consumption have actually got better!
  6. GappySmeg
    GappySmeg Well-Known Member
    Has the bike been modified at all?
    I would at least look at the air filters... my bike has had a very easy life, nonetheless, at 7500 miles the air filters had great streaks of thick chud up in them!!!
  7. PeterT
    PeterT Active Member
    Have you re-set your ECU recently?
  8. PeterT
    I do mine after air filter gets cleaned,
  9. Lozzy
    No I haven't, and just found older thread on the subject and from what it's saying it may do the trick, I'll re-set it and see...thanks :)
  10. Slick
    Slick Elite Member
    o2 eliminator can help too
  11. Lozzy
    Re-set it this morning & it's much better :)
    as they say...every days a school day :)
  12. exuptoy
    exuptoy Elite Member
    How did you reset the ecu, whats the procedure?
  13. Mr OCD
    Mr OCD Well-Known Member
    Disconnect battery for half hour ... Connect and start up, don't touch throttle. Let fans cut in then turn off. Done :)
    • Thanks Thanks x 2
  14. Lozzy
    As per Mr ocd's reply & it's sorted it nicely so a big brucie bonus not having to get me wallet out :) can spend it on fuel & ice creams in this heatwave that's a coming :D
