SP1 SP2 Wheel Swap Question
Discussion in 'General 1000RR Discussion' started by Mfpcopy, Jan 16, 2021.
  1. Mfpcopy
    Mfpcopy New Member
    Anyone know if the discs/sprocket from the OEM 1 wheels are a direct bolt on to the Marchesinis from the 2?
  2. Ian E
    Ian E Active Member
  3. RC45
    RC45 Active Member
    Cush drive is the same as base/SP but front rotors are unique SP2 Honda/Brembo/Marchesini mashup - no other setup shares the bolt circle diameter.
  4. Paul8
    Paul8 Active Member
    Marchesini also do wheel sets specific to the 17 - 19 base/SP so plug and play for this option - standard brake discs are usable but a new rear sprocket is required as bcd is different
