Speed sensor plug
Discussion in 'General 1000RR Discussion' started by stuart_g, Sep 11, 2019.
  1. stuart_g
    stuart_g Active Member
    Hi all,
    May be a long shot but does anyone know what the speed sensor wiring plug type is called?
    I am installing a quick shifter and it needs a connection to the signal wire from the speed sensor but I don't want to connect this in to the bikes wiring loom in case i want to remove it at any point. I want a plug and socket so that I can make a straight through lead with a spur off it for the quick shifter.
    I have tried a search by looking at photo's of the speed sensor and trying to match it up but not a lot of luck that way.
    Any help would be appreciated.
    Cheers
  2. bazzashadow
    bazzashadow Elite Member
    Have you got a picture of yours you can post up?
  3. bazzashadow
