Hi, I bought a speedo healer & a sprocket a while back. Have fitted the sprocket but not the speedo healer. Can someone tell me how long it takes to install and if easy to setup. As looks very complicated looking at the instructions I found online.. Also is this only for correcting the speedo speed reading? Or any other functions? Thanks
Just corrects the speedo. Plugging it in isn't so hard once you know which connector under the tank you need to plug in to. Then I'd get their App to work out the settings and take for a ride to check. I checked this against a GPS based speedo App on my phone. Not perfectly accurate, but gives a good indication of how close you are to the speedo reading.
