SpeedoHealer V4
Discussion in 'Parts, Accessories & Clothing' started by Muffking, Sep 20, 2012.
  1. Muffking
    SpeedoHealer V4 brand new.
    This is to correct your speedo especially if you have altered your gearing.
    It's the latest V4 model which is waterproof, has it's own LED display and is half the size of the old one so that it takes up virtually no room.
    It comes with a Top Speed Memory button, which is a micro switch that you can cable tie out of the way to recall your top speed on the dash.
    And includes the SH-H02 harness to plug & play with the speedo sensor under the tank on the RR4/5 Blade, CBR600 RR5/6, CBF1000 (06-10) & CB1000R (08-10). Any other model would require a different harnes.
    For more info see HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro, X-TRE, FI Tuner Pro, Brake Light Pro, MM5, OBD Tool
    These are £85 on Ebay, although I can't see one listed for the Blade.
    The first £65 inc. delivery gets the lot.
  2. Muffking
  3. Muffking
