Received this yesterday. Anyone already using one? P.S. First person to mention Brembo gets a prize Speedycom*Performance*Ltd...
That is a lot for a lever? is it really a substitute for changing the master cylinder to a Brembo? What is it like? Does it work and is there a clutch lever to match? thanks.
Tested this yesterday and it seems to work as described The pivot (ratio) has about 30 clicks of adjustment. I have it fully wound in and the bike feels like it has a different MC. Less lever travel and more power for less pressure. Lever position also has loads of adjustment, as does lever length.
Yup still happy. Can't compare directly to Brembo MC, but I couldn't expect a lever alone to be any better really. Negative points are that I can't really use full adjustment as it fouls the clocks on full lock, but this is actually because of the positioning of my lever perch, which I can't move because of HEL brake line setup.
