Sportec M7 RR - Metzeler track day temp
Discussion in 'General 1000RR Discussion' started by Remal, Aug 11, 2015.
  1. Remal
    Just interested to find out if anyone has used these tyres on track and what tyre pressures you used,
    I ask as I set mine for road at 34 front and rear. it was hot out when I used them on the road and felt good.
    I put my tyre warmers on them before Brands last week (report soon when my Macbook is fixed) and run checked the temp Hot before going out and set both to 30PSI front and rear. So about 26-27 cold.
    And then never needed to adjust them again. I was only in the novice group as it was my first time at Brands and went with mates who had not done lots of TD's. They felt bloody good on track, no issues at all and felt perfect coming through Clarke curve onto the straight in 2nd, through 3rd and into 4th doing 90-130 exiting the corner on the the straight.
    So just interested to find out what others are using. And how these tyres felt on the pressure you where using
  2. Blackness
    Blackness Active Member
    Ive ran these on a track day and they were brilliant mate !
    I got the tyre guy to do my pressures for me and he stuck in 30psi front and 28 in the rear !
    I was a bit dubious at that lower pressure but it worked spot on and got real hot and sticky, and they held beautifully !
    I run a 55 on the rear and its been the best tyre set up I've ever had...
  3. Moon
    Moon Active Member
    I been running 30 front and 28-29 rear (hot) and they are spot on!
