Spots on the OZ wheels
Discussion in 'General 1000RR Discussion' started by Demmel, Nov 30, 2018.
  1. Demmel
    Demmel Member
    Hello! Today I found spots on my OZ wheels. Tell me, is it possible to remove them?
    Why did they appear?
  2. nigelrb
    It appears to be slight moisture that gathered and then dribbled down. WD 40 should remove it.
  3. Cbrjay
    Cbrjay Well-Known Member
    What has been used to clean them with?
  4. Demmel
    Demmel Member
    Sometimes I used anti-silicone (degreasing) to remove the chain lubrication from the wheels and immediately wet it with water. Nothing else. In sunlight, these spots are much less noticeable.
    Tomorrow I will try WD 40 for cleaning. The reason for these spots could be a constant change in the temperature of the garage? Within 5-6 degrees
