Spring Replenishments
Discussion in 'Cox Honda' started by CoxHonda, Feb 29, 2012.
  1. CoxHonda
    CoxHonda Active Member
    Hello Everyone, as we are the end of feburary we are nearing spring and the nasty bitter cold weather is almost behind us all,
    as some of you will be bringing your bikes out of hibernation soon you may need a few things to give the old 'gal some life,
    maybe some spark plugs, a new battery, or maybe she just need cleaning up so she looks stunning on the roads!
    if you need anything for the spring then make sure to come to us as we will give YOU the best possible prices! come direct to me and ill see what else i can do onto of the usual discount!
    this applies to Oils, Filters, Cleaning Products (enquire) (MucOFF), Chain lubes or waxes, sparkplugs and batteries...
    Regards and Looking forward to hearing from you!
    Stu.
  2. Repsol Rob
    Repsol Rob Elite Member
    Stu do you do s service kit for 2008 + inc oil filters etc ? i guess it would all be honda oem ? or can u do deal on K&N etc.....
  3. CoxHonda
    Hello Rob, if you tell me what you would want to be ordering then i would be able to get you a price i can incorperate K&N filters if you would like...
    Regards
    Stu.
  4. Repsol Rob
    K&N oil filter plus air filter......and a suitable oil ? what wouild you recommend ?
  5. CoxHonda
    Are you wanting both K&N or just the oil filter...
    one of my techys said that the best is 10w30 he uses it himself in his own blade,
    Regards
    Stu.
  6. Repsol Rob
    both.....
  7. CoxHonda
    Okay well i can get you them, £10 for the oil filter, £50 for the air filter, how much oil would you be wanting? if you are doing a full change you will need 4L which we supply at the cost of usually £34.99 if you order with the oil and air filter then i will do it for £24.99,
    Regards
    Stu.
  8. Smiler
    Smiler Active Member
    in need of some muc off soon and castrol chain lube......
  9. CoxHonda
    Just let me know when Smiler! and ill get you a price,
    Regards
    Stu.
